Linnbass
Alguien ha probado estos productos de P21s para llantas y neumaticos..
tengo en mente probarlos
http://i12.***********/34nijd4.jpg http://i13.***********/34oprv8.jpg http://i5.***********/2yuy8hc.jpg http://i5.***********/2rgf4nd.jpg
* P21-S FelgenSchutz - Protectant
Protects aluminium and steel rims from corrosion
Generates a long-lasting, colourless protective film against environmental influences (rain, snow etc.) and hot dust from braking. Preserves the value and appearance of wheel rims.
Ideal for winter (preservation when salt is used for icy roads, winterstorage of aluminium and steel wheel rims).
Does not attack any kind of surface. Can be removed without difficulty if required, e.g. with P21-S PowerGel.
* P21-S ReifenGlanz - Tyre Shine
Long-lasting gloss for faded tyres
Provides evenly deep black and shiny tyres. Gives long-lasting protection against weathering and environmental influences (e.g fading through UV-rays).
- Keeps tyres supple, prevents brittleness.
- Survives many rainy journeys and approx.
2-3 car-wash-cycles.
* P21-S Felgen Wachs - Rim Wax
The Easy-to-Clean-Effect of the P21-S Rim Wax prevents dirt from adhering on the rim surface.
Prevents dirt from strongly adhering to the surface. Fewer contamination means easier and faster removal. It offers a long-persisting water-repellent-effect and protects against brake dust, humidity etc. for about 3-4 washes.
Besides, it is easy to apply and to handle. P21-S PowerGel provides self-active cleaning and because of its gel-formula is very economical and effective.
* P21-S PowerGel
THE solution against strong brake-dust
Removes even persistent dirt like extreme brake-dust resulting from a sportive driving style.
With an extremely quick effect and application (only 3-5 minutes of application time!) and at the same time absolutely acid-free.
It does not attack any material and is therefore safe for all surfaces. P21-S PowerGel provides self-active cleaning and because of its gel-formula is very economical and effective.
gracias
* P21-S PowerGel
gracias
