maesal dijo:Me pido uno de estos, ¿eh?.
¿Cuánto cuesta?.
Con ellos simplemente hay que pegar las esponjas de pulido y ya está, ¿no?.
Gracias.
Detalles dijo:Los platos para PC cuestan 14,95€ y ya simplemete hay que pegar la esponja.
Son de inmejorable calidad ya que son los de poliuretano, que amortiguan vibraciones, que usan en EEUU
GLOSS dijo:Una dudilla:
Según Dbynon, lo más eficiente es el conjunto disco velcro de 5 pulgadas + esponjas de 6-7 pulgadas. Mi pregunta es:
Cuál es el tamaño del disco y de las esponjas que ofrece Ricardo ??
sl2
"Velcro backing plates come in a wide range of sizes. For safety, be sure to use a backing plate that is slightly small than your pads. In general, the 5-inch counterweight (p/n 874011) should be used with a 5-inch or smaller backing plate, whereas the 6-inch counterweight (p/n 699933) must be used with a backing plate larger than 5 inches. Weight is the true determining factor for the proper counterweight, not the backing plate or pad size. If your machine vibrates excessively, you may need to switch counter weights. You will need a Torx driver (size T15, not supplied with the machine) to swap counterweights. While on the subject of weight and counterweight, the lighter the backing plate and pad combination the more efficient the machine will be. Some suppliers assemble backing plate and pad combinations that have no business being connected to the PC 7424. After several years experimenting with a variety of backing plate and pad combinations, I have concluded that a light weight, 5-inch, flexible backing plate used in conjunction with a 6- to 7-inch pad achieves the best results. Larger backing plates and pads apply too much torque on the motor and rob efficiency."
jajaja y no los borran cuando paso cierto tiempo?
