KFZ SD8 (TMT 900): (PRECIO 86.7€, tiene 21 unidades)
[FONT=Verdana, Arial, Helvetica, sans-serif]
The layer thickness measuring instrument TMT-900 is the perfect equipment for the private use. Very fast and economically you can examine, whether a vehicle was after-painted or not.
The operation is extremely simple. [/FONT]
Put on measuring pistol, pull trigger and read off measured value - and you know whether your dream car is accident-free or not ![/FONT]
F-probe
Non destructive measurement of non-magnetic layers (lacquer, dye films, powder coatings, aluminum, chrome, copper, enamel, paper, rubber, ...) on magnetic metals such as steel, Iron, alloys... [/FONT]
Operational areas:
Private examination of the lacquer thickness localization of underground changes (primed holes or primed depressions), quality control for paint work, accident damages at cars. For professional use we recommend our models 8820, 8821, 8822, 8825 and 8826.[/FONT]
Product highlight:
ISO-2178 and ISO-2361 conform, automatic material recognition, automatic point measurement large measuring range with high resolution, digital display maintenance-free enterprise, ABS plastic housing[/FONT]
Scope of supply:
Measuring instrument TMT-900 with battery
Transportation bag
Calibration disc[/FONT]
24-Hour-Dispatch-Guarantee
The day we receive our payment the gauge is dispatched. We need 2-4 days for delieveries to U.K.
Professional handling
You automatically receive a note of payment and a dispatch for the ordered articles. Each delievery is attached a bill with proven VAT.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- Many further gauges in our EBAY-Shop -
muss nicht das phep von hanna, sera, jbl, dennerle oder wtw sein. Unsere Geräte tun auch ihren Dienst
[/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]
Technische Daten:[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Messbereich/Measuring range:[/FONT]0 - 1000 µm (0 - 40 mils)
[FONT=Verdana, Arial, Helvetica, sans-serif]Messfehler/Measuring error:[/FONT]± 3% + 4 Digits
[FONT=Verdana, Arial, Helvetica, sans-serif]Messgenauigkeit/Resolution:[/FONT]1 µm (0,1 mil)
[FONT=Verdana, Arial, Helvetica, sans-serif]Stromversorgung/Power supply:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Batterie 9V[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Abmessungen/Dimension:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]42 x 148 x 105 mm[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Gewicht/Weight:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]260g[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Automatische Temperatur Kompensation:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]5°C – 50° ATC[/FONT]
[FONT=Verdana, Arial, HelvA?etica, sans-serif]Konformität/Conformity:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]CE-konform nach EN 50081-1 und EN 50082-1[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Anleitung/Manual:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]deutsch & english[/FONT]
CM-8821: (PRECIO 130€, pero no confirma cuantos tiene)
This layer thickness measuring instrument LA CM-8821 is stable, easily to transport light in weight . Despite its complexity and progressiveness it is simple and comfort-ably to use. This maintenance-free equipment is laid out for the rough external employment and many years usage. The magnet-inductive measuring method is conform to DIN EN ISO 2178 and ASTM B499. [/FONT]
F-probe
Operational areas:
Autotrade for the examination of the lacquer thickness localization of underground changes (primed holes or primed depressions), quality control for paint work, accident damages at cars[/FONT]
Product highlight:
[/FONT]
Technical data:[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Messbereich/Measuring range:[/FONT]0-1000 µm
[FONT=Verdana, Arial, Helvetica, sans-serif]Messfehler/Measuring error:[/FONT]±1-3% / 2.5µm
[FONT=Verdana, Arial, Helvetica, sans-serif]Messgenauigkeit/Resolution:[/FONT]0.1µm bis 99.9µm
[FONT=Verdana, Arial, Helvetica, sans-serif]Stromversorgung/Power supply:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Batterie 4×1.5V(AAA)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Abmessungen/Dimension:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]161mm(L)×69mm(B)×32mm(H)[/FONT]
[FONT=Verdana, Arial, HelvA ?etica, sans-serif]Konformität/Conformity:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]CE-konform nach EN 50081-1 und EN 50082-1[/FONT]
