Video Spit & Shine
He estado leyendo en Autopia sobre este método y aunque también tienen dudas, parece ser que hemos acertado con el metodo corregidme si me equivoco:
El proceso es:
Aplicar una capa de cera en todo el coche.
Retirar cera.
Aplicar en un trozo QD a baja temperatura.
Aplicar en ese trozo cera de nuevo.
Retirar sobrantes.
Esto es lo que entendido yo, pero sólo se inglés para defenderme, con vuestro permiso os pego aquí un post en inglés por si alguien entiende otra cosa...
Method: Dampen the MF square and load it with just enough wax to thinly cover a small area - 1/4 hood or 1/2 door. Wipe it onto the work area and continue wiping until most of the wax disappears. Mist lightly as needed to keep a few water droplets on the surface. Move to the next work area and repeat. Now to the third work area. For the fourth step go back and redo the first area. Next do area four, then two, then five, then three, then six, etc. After you do the final area you’ll have a car with a lot of spots of hazed wax - but not to worry. Lightly mist an area with the cold water - 1/2 hood or door - and lightly buff with a MF towel. Turn the towel frequently. When the towel becomes damp switch to a new towel. After 24 hours you can repeat the procedure, and each time it increases the depth of the shine.
I don’t have an objective method of measuring the hardness of the spit shined carnauba, but subjectively - - bug removal is very nearly as easy as it is with only Zaino on the front of the car.
This is not a method for those of you who wash your car once a week and wax once a month, but it is great if you QD every day and seldom wash the car. I have had the best results with Pinnacle Crystal Mist QD which I keep in the refrigerator.
Bueno, como dices lo hago yo, sólo q la cera la dejo el tiempo q necesite, no necesariamente ha de darse a todo el coche y retirar, por ejemplo P21S, Collinites en pasta, Souveran las aplico y retiro panel por panel.
Salu2 !!
Eso me deja más tranquilo.
Entonces aplicao un panel, retiro, QD Fresquito y Cera de nuevo, así panel por panel...¿NO?, alguna he sido interrumpido a medio aplicar cera y me he dejado un panel un rato sin retirar y luego me las he visto canutas para retirar una vez que la cera se ha quedado ultra seca...
O en vez de QD, agua destilada fresquita, yo uso pulverizadores pequeños que nebulizan más que pulverizar, hay q usar poco líquido y trabajar la cera hasta que no se vea nada de líquido.
Si alguna vez se te seca, puedes pulverizar QD y te ayudas. Por ejemplo las Collinite en pasta si las das algo gruesas te dejan restos. Si les das con un QD que limpie bien, como el DG FC&S y pasas una bayeta de pelo corto lo limpiarás fácilmente.
coña... esto es por lo que prguntaba yo en su dia, lo vi por un foro frances, tengo curiosidad porutilizar esta tecnica, haber que resultado deja.
El otro dia he aplicado una segunda capa de cera a mi coche. A la mañana siguiente le he dado con un pulverizador que pulveriza muy fino y agua destilada muy muy fria, estaba unas 12 horas en el cajón de 0 grados.
Solo aplicar el agua y retirar con toalla mullida.
Según he leido sirve para que se asiente bien la cera, sobre todo ahora que va haciendo mas calor. Ademas ha ganado algo de brillo. Ya veremos si mejorar asi la duración, por lo menos ha sido una técnica barata :)
Saludos!
entonces el spit and shine ¿que es?¿sólo un método de dar cera para que quede mejor?
lo de darla en circulos es solo para repartir mejorel material, dejando una capa mas homogénea. me imagino que esto pierde sentido tanto en cuanto más liquida sea y mas tarde en secar (dejando que se autonivele)
soy pintor de brocha gorda y los años aplicando diferentes productos te da una comprensión de porqué se aplican así
todo lo que sea aplicar un producto (el que sea) sigue ciertos parámetros lógicos
Lo hice ayer por la tarde/noche con QD y si parece que coge más brillo...pero tampoco es para tirar cohetes, veremos si gano en tiempo de brillo...al menos lo pasé bien investigando.
